chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
starg4ze
Mar 12, 2009Aspirant
Well...It does not seem like the 4.2.3 works.
I do the
with no errors
and then I do the
and getting
dmesg only shows:
I do the
insmod vboxdrv.ko
insmod vboxnetflt.ko
with no errors
and then I do the
/etc/init.d/vboxdrv start
and getting
modprobe vboxnetflt failed. Please use 'dmesg' to find out why
dmesg only shows:
vboxdrv: Trying to deactivate the NMI watchdog permanently...
vboxdrv: Successfully done.
vboxdrv: Found 2 processor cores.
vboxdrv: fAsync=0 offMin=0x1b0 offMax=0x8c1
vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
vboxdrv: Successfully loaded version 2.1.4 (interface 0x000a0009).
