chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Mar 12, 2009Luminary
Yes, you need 4.2.4 for the modules I've supplied, they won't work with the kernel from 4.2.3.
