chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Mar 19, 2009Luminary
I'm running 2003 on the VM, going to try the IDE->SATA change tonight on it.
I'd probably go with #3.
Could maybe use the Save State, copy, restore, shouldn't take long to run that on the Pro, less than a few minutes, so there isn't much interruption to the VM.
http://srackham.wordpress.com/cloning-a ... -machines/
