chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Apr 16, 2009Luminary
VirtualBox 2.2.0 is out now. I have it installed on my box, but had a few loops on the upgrade since I've also updated firmware a few times since. I'll try and update the guides on here for installing on the weekend to use 2.2.0.
Also using my iPhone with iTunes in the VM, USB passthru from the ReadyNAS works well :)
