chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Apr 16, 2009Tutor
hm, i just installed virtualbox 2.2.
it installs a lot of junk along the way (downloads 130 mb additional stuff), but it installed without a single error and also compiled the modules just fine. i havent tried to run it yet but i doubt it will cause problems.
edit: just started the vm. works without a problem.
