chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
devbobo
Apr 21, 2009Aspirant
chirpa wrote: Any logs in /var/log/syslog from the VirtualBox kernel modules?
I looked through the logs but didn't really see anything that stood out from normal operation.
I ended up transferring some VMs across that I had setup on my Mac and just hacked the xml files to get it to work.
