chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Apr 22, 2009Luminary
No issues of leaving it there. In 4.2.5, the kernel modules might break though and need re-compiling.
You can reverse the apt-get install of virtualbox, apt-get remove, and delete the modules, then its pretty much uninstalled.
