chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
muggsy
Jun 24, 2009Aspirant
Chirpa, I used your instructions to load my VM up at startup. But it doesn't seem to be working. The script is fine coz I can load it that way. Any ideas? Windows 7 seems to be working a treat on it, so appreciate the thread a lot.
