chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
muggsy
Jun 24, 2009Aspirant
chirpa wrote: Referring to this?
I will need to test it out. The script works manually, so its probably a path/environment when running it from the automated system control.
yeah that's the one. Any logs I can check? Other than that it works great. Got my 4GB upgrade for me PRO, and I'll pop an Win 2K3 server on there as well.
