chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MikeMcr1
Aug 02, 2009Aspirant
I have been following the instructions in the first post but get the following dependency errors:
I am running firmware 4.2.5. Any ideas how I fix this? Thanks.
# apt-get update && apt-get install build-essential
The following packages have unmet dependencies:
build-essential: Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:4.1.1) but it is not going to be installed
# apt-get install libc6-dev
libc6-dev: Depends: libc6 (= 2.7-18) but 2.3.6.ds1-13etch9+b1 is to be installed
Depends: linux-libc-dev but it is not installable
