chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
msetnarba
Aug 20, 2009Aspirant
hello,
I'm trying to install Virtualbox on a NVX but I've a problem at the end of this command :
# apt-get install virtualbox-3.0
I've this message in vbox-install.log
I've the 4.2.5 firmware and I use 4.2.5 sources
I follow Chirpa's instructions......
Anyone have an idea?
Thx
** Compiling vboxdrv
Makefile:150: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
Makefile:158: *** Error: /usr/src/linux (version 2.6.27.6.RNx86.2.1) does not match the current kernel (version 2.6.27.6.RNx86.1.1). Stop.
Thx
