chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
msetnarba
Aug 21, 2009Aspirant
thx a lot .
I've tried but I've a different error now :
perhaps I miss something ......
Reading package lists... Done
Building dependency tree... Done
Recommended packages:
libsdl-ttf2.0-0 linux-headers libhal1 pdf-viewer libgl1 python-central
The following NEW packages will be installed:
virtualbox-3.0
0 upgraded, 1 newly installed, 0 to remove and 5 not upgraded.
Need to get 0B/50.2MB of archives.
After unpacking 102MB of additional disk space will be used.
Preconfiguring packages ...
(Reading database ... 22370 files and directories currently installed.)
Unpacking virtualbox-3.0 (from .../virtualbox-3.0_3.0.4-50677%5fDebian%5fetch_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/virtualbox-3.0_3.0.4-50677%5fDebian%5fetch_i386.deb (--unpack):
subprocess pre-installation script returned error exit status 123
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
