chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Aug 21, 2009Luminary
Copy the defconfig as noted in my other thread. Then do a 'make clean;make all' in the kernel sources, then try installing VirtualBox again. Should work.
