chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
msetnarba
Aug 22, 2009Aspirant
same thing
here is exactly what I've done :
during vbox install I've this message :
# echo "deb http://download.virtualbox.org/virtualbox/debian etch non-free" >> /etc/apt/sources.list
# wget -q http://download.virtualbox.org/virtualbox/debian/sun_vbox.asc -O- | apt-key add -
# apt-get update && apt-get install build-essential
# wget -q http://www.readynas.com/download/GPL/RNDP6xxx_4.2.5_WW_src.zip
# unzip -q RNDP6xxx_4.2.5_WW_src.zip -d ./GPL
# cd GPL/linux-x86-2.6/
# cp arch/x86/configs/tolapai_defconfig arch/x86/configs/i386_defconfig
# make menuconfig (I do this otherwise I've this error : (missing kernel .config file))
# make clean;make all
# ln -s /c/backup/GPL/linux-x86-2.6/ /usr/src/linux
# KERN_DIR=/usr/src/linux
# wget http://download.virtualbox.org/virtualbox/3.0.4/VirtualBox-3.0.4-50677-Linux_x86.run
# chmod +x VirtualBox-3.0.4-50677-Linux_x86.run
# ./VirtualBox-3.0.4-50677-Linux_x86.run
Python found: python, installing bindings...
/bin/bash: python: command not found
Building the VirtualBox vboxdrv kernel module
Failed to build the vboxdrv kernel module.
