chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
msetnarba
Aug 26, 2009Aspirant
thx Chirpa,
with the topic concerning NVx, it works.
I replace the
by
perhpas you could merge it with this one.
but thx a lot for your great help
I replace the
cp arch/x86/configs/tolapai_defconfig arch/x86/configs/i386_defconfig
by
cp arch/x86/configs/tolapai_Makefile Makefile
cp arch/x86/configs/tolapai_defconfig .config
