chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
posure
Sep 29, 2009Aspirant
chirpa wrote: Referring to this?
I will need to test it out. The script works manually, so its probably a path/environment when running it from the automated system control.
I was able to get the startup/shutdown script to work eventually, but not as an addon (it failed as an addon because the vbox kernel extensions weren't loaded when the addon tries to start):
# mv /root/vboxctrl.sh /etc/init.d/
# cd /etc/init.d
# update-rc.d vboxctrl.sh defaults 99 10
