chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 16, 2009Aspirant
Have gotten down to apt get update step but get the following errors
When I try to proceed using the make menuconfig or make clean step I obviously get "no command error". Any help would be appreciated.
BigBearf
nas-EA-33-DF:/# apt-get install build-essential
Reading package lists... Done
Building dependency tree... Done
build-essential is already the newest version.
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
build-essential: Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: make but it is not going to be installed
Depends: dpkg-dev (>= 1.13.5) but it is not going to be installed
g++-4.1: Depends: libstdc++6-4.1-dev (= 4.1.1-21) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
nas-EA-33-DF:/# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
dpkg-dev libc6-dev libstdc++6-4.1-dev make
Suggested packages:
debian-keyring glibc-doc manpages-dev libstdc++6-4.1-doc make-doc-non-dfsg
Recommended packages:
bzip2
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 0 to remove and 41 not upgraded.
11 not fully installed or removed.
Need to get 0B/4899kB of archives.
After unpacking 23.5MB of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
libc6-dev libstdc++6-4.1-dev make dpkg-dev
Install these packages without verification [y/N]? y
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 17645 files and directories currently installed.)
Unpacking libc6-dev (from .../libc6-dev_2.3.6.ds1-13etch9+b1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libc6-dev_2.3.6.ds1-13etch9+b1_i386.deb (--unpack):
unable to create `./usr/lib/libnsl.a': No space left on device
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Unpacking libstdc++6-4.1-dev (from .../libstdc++6-4.1-dev_4.1.1-21_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libstdc++6-4.1-dev_4.1.1-21_i386.deb (--unpack):
unable to create `./usr/include/c++/4.1.2/bits/stl_construct.h': No space left on device
Unpacking make (from .../archives/make_3.81-2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/make_3.81-2_i386.deb (--unpack):
error creating directory `./usr/share/locale/be/LC_MESSAGES': No space left on device
Unpacking dpkg-dev (from .../dpkg-dev_1.13.26_all.deb) ...
dpkg: error processing /var/cache/apt/archives/dpkg-dev_1.13.26_all.deb (--unpack):
unable to create `./usr/bin/dpkg-gencontrol': No space left on device
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
nas-EA-33-DF:/#
BigBearf
