chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 17, 2009Aspirant
OK tried VB install but no luck so far. I think I have filled up the Root partition and would like to know what I can safely delete. Here is a "du" output.
nas-EA-33-DF:/# du --max-depth=1 -h -x
16K ./lost+found
1.7G ./GPL
3.1M ./bin
0 ./sys
0 ./ramfs
4.0K ./mnt
6.7M ./etc
28K ./tmp
0 ./USB
11M ./lib
480K ./__MACOSX
420K ./_READYNAS_CONFIG-1
4.0K ./c
4.0K ./initrd
3.8M ./sbin
11M ./frontview
28K ./root
0 ./dev
2.4M ./opt
217M ./usr
0 ./proc
111M ./var
16K ./.Dekoh
228K ./home
2.5G .
nas-EA-33-DF:/# cd /GPL
nas-EA-33-DF:/GPL# du --max-depth=1 -h -x
36M ./apache2-2.2.6
128K ./pwauth-2.3.6
476K ./sysklogd-1.4.1
368K ./mktemp-1.5
84K ./libfile-remove-perl-0.31
68K ./libtext-wrapi18n-perl-0.06
3.5M ./rsync-3.0.5
2.7M ./bzip2-1.0.3
20K ./libreadynas_lgpl
544K ./libhtml-parser-perl-3.55
1.1M ./iscsitarget-0.4.17
355M ./linux-x86-2.6
3.5M ./bash-3.1dfsg
644K ./liburi-perl-1.35
4.0M ./iptables-1.3.6.0debian1
1.9M ./libevent-1.1a
5.6M ./openssh-4.3p2
756K ./libedit-2.9.cvs.20050518
23M ./libxml2-2.6.27.dfsg
14M ./flac-1.2.1
3.5M ./lvm2-2.02.06
4.1M ./libgd2-2.0.33
1.6M ./mdadm-2.6.4
2.9M ./sudo-1.6.8p12
1.1M ./vlan-1.9
1.1M ./pciutils-2.2.4~pre4
104K ./libdevel-symdump-perl-2.03
2.4M ./smartmontools-5.38
308K ./base-files-4.0.1~bpo40+1
92K ./lcd
340K ./miniupnpd
44K ./gpio
2.4M ./libmad-0.15.1b
14M ./busybox-1.7.0
1.7M ./libdbi-perl-1.53
1.5M ./gzip-1.3.5
3.6M ./zip-2.32
600K ./ethtool-5
264K ./portmap-5
20M ./cupsys-1.1.14
18M ./proftpd-1.3.2
14M ./shadow-4.0.18.1
3.1M ./ntfs-3g-1.2531
340K ./hdparm-6.9
1.3M ./mawk-1.3.3
48K ./debian-backports-keyring-2007.06.10
536K ./host-20000331
208K ./makedev-2.3.1
8.4M ./cyrus-sasl2-2.1.22.dfsg1
200K ./libnet-daemon-perl-0.38
73M ./gcc-4.1-4.1.1ds2
2.7M ./expat-1.95.8
2.0M ./slang2-2.0.6
11M ./tar-1.16
424K ./ucf-2.0020
484K ./at-3.1.10
1.5M ./libnfsidmap-0.18
10M ./libapache2-mod-perl2-2.0.2
696K ./udev-0.105
664K ./debianutils-2.17
4.3M ./devmapper-1.02.08
308K ./netbase-4.29
5.9M ./unzip-5.52
5.9M ./libvorbis-1.1.2.dfsg
11M ./fuppes-4.01c1-p3
256K ./mod_authnz_external-3.1.0
224K ./libapache2-mod-auth-pam-1.1.1
1.2M ./wireless-tools-28
9.8M ./netatalk-2.0.3
4.2M ./nfs-utils-1.1.2
2.8M ./libjpeg6b-6b
1.2M ./readynas-x86-kernel-modules
61M ./perl-5.8.8
15M ./ncurses-5.5
7.4M ./findutils-4.2.28
688K ./zlib-1.2.3
112K ./lvm-common-1.5.20
24M ./gnutls13-1.4.4
50M ./db4.3-4.3.29
3.1M ./file-4.17
60K ./debian-archive-keyring-2007.07.31~etch1
2.4M ./popt-1.10
2.3M ./gdbm-1.8.3
588K ./nv6memtest
3.4M ./libsepol-1.14
148K ./libplrpc-perl-0.2017
17M ./dpkg-1.13.25
63M ./samba
19M ./glibc-2.3.6.ds1
828K ./grep-2.5.1.ds2
1.7M ./db3-3.2.9+dfsg
240K ./acpid-1.0.4
648K ./iputils-20020927
4.3M ./libexif-0.6.16
260K ./base-passwd-3.5.11
5.7M ./exim-3.36
424K ./dosfstools-2.11
56M ./db4.4-4.4.20
4.8M ./wget-1.10.2
3.0M ./ncftp-3.2.0
436K ./logrotate-3.7.1
2.9M ./libid3tag-0.15.1b
124K ./libident-0.22
2.7M ./tzdata-2008h
1.6M ./ifupdown-0.6.8
120K ./liblocale-gettext-perl-1.05
168K ./libnet-netmask-perl-1.9012
4.5M ./apr-util-1.2.7+dfsg
96K ./ddrescue-1.10
1.9M ./libusb-0.1.12
6.2M ./nv6bootloader
876K ./sysfsutils-2.1.0
168K ./mime-support-3.39
8.2M ./apt-0.6.46.4
4.3M ./libpng-1.2.15~beta5
4.7M ./libgcrypt11-1.2.3
2.2M ./libogg-1.1.3
68K ./hostname-2.93
888K ./minidlna
16M ./ffmpeg-debian-0.svn20080206
396K ./cracklib2-2.7
1.4M ./sysvinit-2.86.ds1
96K ./libfile-ncopy-perl-0.34
688K ./libpci2-2.1.11
1.7M ./libdaemon-0.12
2.5M ./opencdk8-0.5.9
2.0M ./tct-1.11
12M ./sqlite3-3.5.9
3.3M ./cpio-2.6
1.5M ./net-tools-1.60
4.1M ./gphoto2-2.2.0
5.5M ./mt-daapd
4.7M ./libgpg-error-1.4
6.2M ./apr-1.2.7
25M ./net-snmp-5.2.3
948K ./noflushd
4.4M ./lzo-1.08
468K ./udhcp-0.9.8cvs20050303
76K ./libtext-iconv-perl-1.4
11M ./ntp-4.2.2.p4+dfsg
1.2M ./libwww-perl-5.805
2.2M ./librpcsecgss-0.17
21M ./openssl-0.9.8c
88K ./libhtml-tagset-perl-3.10
1.4M ./procps-3.2.7
23M ./e2fsprogs-1.41.3
14M ./openldap2-2.1.30
16M ./util-linux-2.13.1.1
348K ./libcap-1.10
912K ./tftp-hpa-0.43
2.4M ./iproute-20061002
49M ./krb5-1.4.4
3.4M ./diffutils-2.8.1
5.2M ./libapreq2-2.08
4.9M ./libtasn1-3-0.3.6
1.7M ./freetype-2.2.1
2.3M ./libgssglue-0.1
1.9M ./libdvdread-0.9.7
612K ./libdbd-mysql-perl-3.0008
6.1M ./readline5-5.2
472K ./cron-3.0pl1
4.3M ./linux-atm-2.4.1
12M ./postgresql-8.1-8.1.11
640K ./attr-2.4.32
196K ./openbsd-inetd-0.20050402
5.0M ./nut
508K ./tcp-wrappers-7.6.dbs
2.8M ./msmtp-1.4.9
1.1M ./mdadm-2.6.7
132K ./memtester-2.93.1
2.4M ./iscsitarget-0.4.16+svn162
4.5M ./sed-4.1.5
11M ./libidn-0.6.5
1.1M ./ifplugd-0.28
18M ./gnupg-1.4.6
31M ./db4.2-4.2.52+dfsg
84K ./libtext-charwidth-perl-0.04
64K ./dd_rescue
28M ./squeezecenter-7.3.2
89M ./mysql-dfsg-5.0-5.0.32
1.5M ./adduser-3.102
68K ./update-inetd-4.27
3.6M ./libselinux-1.32
20M ./libgphoto2-2.2.1
16M ./busybox-1.10.1
5.2M ./lm-sensors-2.10.1
928K ./bvi-1.3.2
7.0M ./dbus-1.1.2
5.8M ./faad2-2.6.1
496K ./libhtml-tree-perl-3.19.01
264K ./lsb-3.1
12M ./gsasl-0.2.12
1.1M ./acl-2.2.41
5.2M ./pcre3-6.7+7.4
2.0M ./wizd
5.4M ./coreutils-5.97
1.5M ./quota-3.14
6.9M ./avahi-0.6.21
3.4M ./debconf-1.5.11etch2
456K ./module-init-tools-3.3-pre4
3.5M ./pam-0.79
1.5M ./psmisc-22.3
1.7G .
Looks like GPL has a bunch of extra stuff. Any thoughts on what to delete?
Thanks,
BigBearf
16K ./lost+found
1.7G ./GPL
3.1M ./bin
0 ./sys
0 ./ramfs
4.0K ./mnt
6.7M ./etc
28K ./tmp
0 ./USB
11M ./lib
480K ./__MACOSX
4.0K ./c
4.0K ./initrd
3.8M ./sbin
11M ./frontview
28K ./root
0 ./dev
2.4M ./opt
217M ./usr
0 ./proc
111M ./var
16K ./.Dekoh
228K ./home
2.5G .
36M ./apache2-2.2.6
128K ./pwauth-2.3.6
368K ./mktemp-1.5
3.5M ./rsync-3.0.5
2.7M ./bzip2-1.0.3
3.5M ./bash-3.1dfsg
14M ./flac-1.2.1
3.5M ./lvm2-2.02.06
1.6M ./mdadm-2.6.4
1.1M ./vlan-1.9
92K ./lcd
340K ./miniupnpd
44K ./gpio
14M ./busybox-1.7.0
1.5M ./gzip-1.3.5
3.6M ./zip-2.32
600K ./ethtool-5
264K ./portmap-5
20M ./cupsys-1.1.14
18M ./proftpd-1.3.2
340K ./hdparm-6.9
1.3M ./mawk-1.3.3
2.7M ./expat-1.95.8
2.0M ./slang2-2.0.6
11M ./tar-1.16
424K ./ucf-2.0020
484K ./at-3.1.10
696K ./udev-0.105
308K ./netbase-4.29
5.9M ./unzip-5.52
2.8M ./libjpeg6b-6b
61M ./perl-5.8.8
15M ./ncurses-5.5
688K ./zlib-1.2.3
50M ./db4.3-4.3.29
3.1M ./file-4.17
2.4M ./popt-1.10
2.3M ./gdbm-1.8.3
588K ./nv6memtest
17M ./dpkg-1.13.25
63M ./samba
240K ./acpid-1.0.4
5.7M ./exim-3.36
56M ./db4.4-4.4.20
4.8M ./wget-1.10.2
3.0M ./ncftp-3.2.0
2.7M ./tzdata-2008h
96K ./ddrescue-1.10
8.2M ./apt-0.6.46.4
2.2M ./libogg-1.1.3
68K ./hostname-2.93
888K ./minidlna
2.0M ./tct-1.11
12M ./sqlite3-3.5.9
3.3M ./cpio-2.6
5.5M ./mt-daapd
6.2M ./apr-1.2.7
948K ./noflushd
4.4M ./lzo-1.08
1.4M ./procps-3.2.7
348K ./libcap-1.10
49M ./krb5-1.4.4
472K ./cron-3.0pl1
640K ./attr-2.4.32
5.0M ./nut
2.8M ./msmtp-1.4.9
1.1M ./mdadm-2.6.7
4.5M ./sed-4.1.5
11M ./libidn-0.6.5
1.1M ./ifplugd-0.28
18M ./gnupg-1.4.6
64K ./dd_rescue
928K ./bvi-1.3.2
7.0M ./dbus-1.1.2
5.8M ./faad2-2.6.1
264K ./lsb-3.1
12M ./gsasl-0.2.12
1.1M ./acl-2.2.41
2.0M ./wizd
1.5M ./quota-3.14
6.9M ./avahi-0.6.21
3.5M ./pam-0.79
1.5M ./psmisc-22.3
1.7G .
Thanks,
BigBearf
