chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 17, 2009Aspirant
I think I answered my own question. I used Fetch and the "Get" command to copy the RNDP6xxx_4.2.5_WW_src.zip file to my desktop and then deleted most of the files in the GPL folder on the RNPP. Things are running OK but I am back to square one. Does the new firmware beta have the updated kernel and would VB install be easier with the new firmware?
BigBearf
BigBearf
