chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 18, 2009Aspirant
Have made some progress with the VB install but I get the following error when trying to run the VB
Chirpa or anyone with any suggestions?
nas-EA-33-DF:/GPL/linux-x86-2.6# ./VirtualBox-3.0.4-50677-Linux_x86.run
Verifying archive integrity... All good.
Uncompressing VirtualBox for Linux installation.........
VirtualBox Version 3.0.4 r50677 (2009-08-04T17:38:26Z) installer
Please install the build and header files for your current Linux kernel.
The current kernel version is 2.6.27.6.RNx86.2.1
Problems were found which would prevent VirtualBox from installing.
Please correct these problems and try again.
