chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Oct 20, 2009Tutor
did you try an apt-get install virtualbox-3.0 ?
thats how i always install my virtualbox
edit: just tried it. together with the kernel-sources provided by chirpa i was easily able to install vbox via apt-get and compile the kernel modules
edit2: just use chirpas kernel-sources and follow the instructions on page 1
