chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Oct 20, 2009Luminary
First option won't work on 4.2.7, it is using pre-compiled binaries I made on 4.2.4 kernel.
The second way will work, if you adjust VB 2.2 for 3.0.8.
If you get the compiling environment setup and the kernel tree ready, you can install it even easier now on 4.2.7. I will try and get full details in the next few days for installing from a clean system. I've already messed with my personal box too much to make it a reliable installation base. Basically, just download and install http://download.virtualbox.org/virtualb ... _amd64.run. Upon installation, it will compile the needed modules, if you have the kernel tree ready to go (apt-get install build-essential, and drop the GPL/linux-kernel-2.6 files in /usr/src/linux)
