chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 21, 2009Aspirant
@chirpa
Deleted the GPL folder and unzipped to /c/backup/GPL and then did "make && make prepare" command and this is the error code I got.
When and how should I run this download? I can download the file and then do I then "Put" the .run file in the which directory and sh it to run and compile the needed modules?
I think I am getting there and thanks for your help. I am determined to get this going just keep the suggestions coming.
Thanks,
BigBearf
nas-EA-33-DF:/backup/GPL/linux-x86-2.6# make && make prepare
HOSTCC scripts/basic/fixdep
HOSTCC scripts/basic/docproc
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/kxgettext.o
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/lex.zconf.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
scripts/kconfig/conf -s arch/x86/Kconfig
*** You have not yet configured your kernel!
*** (missing kernel .config file)
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
make[2]: *** [silentoldconfig] Error 1
make[1]: *** [silentoldconfig] Error 2
make: *** No rule to make target `include/config/auto.conf', needed by `include/config/kernel.release'. Stop.
Basically, just download and install http://download.virtualbox.org/virtualb ... _amd64.run. Upon installation, it will compile the needed modules, if you have the kernel tree ready to go (apt-get install build-essential, and drop the GPL/linux-kernel-2.6 files in /usr/src/linux)
Thanks,
BigBearf
