chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 22, 2009Aspirant
@chirpa
Thanks for the reply. I will try it tonight doing the following:
1. #make oldconfig
2. #make prepare
3. 'chmod +x' the .run file. I downloaded it to the MBP desktop and then using Fetch "Put" in in the Backup directory. Is that the proper place or should it be in the / directory along with the download .zip file that I unzipped into the /c/backup/GPL directory. Where to put file or does it matter?
4. Then './xxx.run' the file that I "Put" with Fetch and made executable with 'chmod +x' command.
Please let me know where to place the .run file and I will post results tonight or tomorrow.
Thanks.
BigBearf
Try 'make oldconfig' first.
If 'make prepare' works, you can 'chmod +x' the .run file, then './blah.run'.
1. #make oldconfig
2. #make prepare
Thanks.
BigBearf
