chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 22, 2009Aspirant
Here is my most recent attempt and results doing the previously mentioned steps.
Any further suggestions?
BigBearf
nas-EA-33-DF:/backup# ./VirtualBox-3.0.8-53138-Linux_amd64.run.sh
Verifying archive integrity... All good.
Uncompressing VirtualBox for Linux installation.........
VirtualBox Version 3.0.8 r53138 (2009-10-02T09:38:05Z) installer
Installing VirtualBox to /opt/VirtualBox
ln: creating symbolic link `/usr/share/applications/virtualbox.desktop' to `/opt/VirtualBox/virtualbox.desktop': No such file or directory
Python found: python, installing bindings...
/bin/bash: python: command not found
Building the VirtualBox vboxdrv kernel module
Failed to build the vboxdrv kernel module.
Please check the log file /var/log/vbox-install.log for more information.
VirtualBox has been installed successfully, but the kernel module could not
be built. When you have fixed the problems preventing this, execute
/etc/init.d/vboxdrv setup
as administrator to build it.
You will find useful information about using VirtualBox in the user manual
/opt/VirtualBox/UserManual.pdf
and in the user FAQ
http://www.virtualbox.org/wiki/User_FAQ
We hope that you enjoy using VirtualBox.
BigBearf
