chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 22, 2009Aspirant
@chirpa
Here are VB install log per the "Please check the log file /var/log/vbox-install.log for more information."
I feel like we are close. Let me know your thoughts or suggestions. Thanks
BigBearf
VirtualBox 3.0.8 r53138 installer, built 2009-10-02T09:38:05Z.
Testing system setup...
System setup appears correct.
Installing VirtualBox to /opt/VirtualBox
Output from the module build process (the Linux kernel build system) follows:
Makefile:150: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
Makefile:158: *** Error: /usr/src/linux (version 2.6.27.6.RNx86.2.1) does not match the current kernel (version 2.6.30.9.RNx86_64.2.1). Stop.
End of the output from the Linux kernel build system.
Installation successful
BigBearf
