chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 22, 2009Aspirant
@chirpa
One final piece of the puzzle
Thanks for your help. Time to crash, will check forum in AM.
BigBearf
nas-EA-33-DF:/opt/VirtualBox# sh VBox.sh
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.30.9.RNx86_64.2.1) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
basename: missing operand
Try `basename --help' for more information.
Unknown application -
nas-EA-33-DF:/opt/VirtualBox# sudo /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel module ...done.
Recompiling VirtualBox kernel module ...failed!
(Look at /var/log/vbox-install.log to find out what went wrong)
BigBearf
