chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Oct 22, 2009Luminary
BigBearf wrote: Makefile:158: *** Error: /usr/src/linux (version 2.6.27.6.RNx86.2.1) does not match the current kernel (version 2.6.30.9.RNx86_64.2.1). Stop.
You have to use matching GPL. You are using the beta firmware, but GPL kernel tree from 4.2.5. Use this kernel tree: viewtopic.php?p=188401#p188401
