chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Bigbearf
Oct 23, 2009Aspirant
@chirpa
OK. I will download the .gz file. Where is the best place to PUT, chmod and install it? Sorry to be dense but trying.
Let me know how I can proceed. I will do a firmware install if necessary but really like 4.2.7 better.
Thanks,
BigBearf
You have to use matching GPL. You are using the beta firmware, but GPL kernel tree from 4.2.5. Use this kernel tree: viewtopic.php?p=188401#p188401
Thanks,
BigBearf
