chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Oct 23, 2009Luminary
Untar/gzip it whereever you like. I usually keep it on /c somewhere, to avoid filling up the OS partition. Then do the symlink to /usr/src/linux as I mentioned previously.
The VirtualBox*.run file can be anywhere, it is just the installer for it. Once installed, you can delete the .run file.
