chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
mdgm-ntgr
Oct 24, 2009NETGEAR Employee Retired
You need to enable the root ssh add-on to enable ssh access to your NAS (note NetGear may deny support if you say e.g. delete something you shouldn't and your NAS stops working). Using linux commands can take a while to get used to.
