chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
beisser1
Oct 26, 2009Tutor
BigBearf wrote:
I see that the .gz file is T51 and I am running T55. Could that be the problem?
Thanks for your help.
BigBearf
no i have the same. the kernel sources havent changed between t51 and 55
