chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Nico21311
Nov 04, 2009Aspirant
hello
Is it possible to put this kernel version 2.6.30.9.RNx86_64.2.1 file on the forum.
Because the kernel of version T51 is not a good version
Thanks by advance.
If it s have an other method for install virtual box please write a clear tutorial.
Because I try 2 week end to install the virtual box without success.
Thanks by advance for your answer.
I using the version 4.2.7 T78
Thanks by advance.
