chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Nov 04, 2009Luminary
No, unless the kernel tree changes, not very often. And then, doesn't need re-installing, just re-compiling the kernel modules.
Its files will remain through firmware upgrades otherwise.
