chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Nico21311
Nov 06, 2009Aspirant
hello
Thanks you chirpas for your tutorial
but i have an other problem
I following your tuto for start VB in same time of readynas but vb don't start automaticly?
Why
I try change VIRTUALBOX!!VirtualBox!!2.1.4!!/root/vboxctrl.sh start!!/root/vboxctrl.sh stop by VIRTUALBOX!!VirtualBox!!3.0.1!!/root/vboxctrl.sh start!!/root/vboxctrl.sh stop
not effect
Thanks by advance for your answer.
Why
not effect
