chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MacManiak
Jan 28, 2010Aspirant
Dwarf wrote: Successfully upgraded to firmware 4.2.9 (I used the patch of super-poussin to remove php before the upgrade !)
No problem with VirtualBox v3.1.2, my WinXP VM is working nice after upgrade !
Dwarf
Helloooooooo
I heard from Rom1 that 64bits system can't be installed ?
I think there's a compilation problem (forget the x64 options ?).
