chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Jan 28, 2010Luminary
64-bit should work, if you install the 64-bit VirtualBox installer.
edit: Need a CPU with VT-x. Notes here: viewtopic.php?p=213421#p213421
