chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
ptaylor874
Jan 31, 2010Tutor
I'm trying to install Windows 2008 R2 (which appears to only be available as 64 bit)...
Just after it boots to the DVD image, it starts loading files, then gets to the point where it's starting Windows. It fails with a Status: 0xc000035a and below that it states
"Info: Attempting to load a 64-bit application, however this CPU is not compatible with 64-bit mode."
I installed this version:
VirtualBox-3.1.2-56127-Linux_amd64.run
