chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Dwarf1
Jan 31, 2010Aspirant
ptaylor874 wrote: I'm trying to install Windows 2008 R2 (which appears to only be available as 64 bit)...
Just after it boots to the DVD image, it starts loading files, then gets to the point where it's starting Windows. It fails with a Status: 0xc000035a and below that it states
"Info: Attempting to load a 64-bit application, however this CPU is not compatible with 64-bit mode."
I installed this version:
VirtualBox-3.1.2-56127-Linux_amd64.run
Hi ptaylor874,
We had got the same error when we've tried to install Win7 Pro x64 on the Pro.
Here is the screenshot of the error (in French), but the last line of the error is the exact translation of your error msg.
I was too busy this WE to try my own installation ... I'd try later
Dwarf
