chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Jan 31, 2010Luminary
Only having 4GB or less RAM is not a 64-bit/32-bit decision. As posted above, the user is trying to run Windows 2008 R2, which is 64-bit only. There is other advantages to 64-bit besides using >3GB RAM.
