chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
mdgm-ntgr
Jan 31, 2010NETGEAR Employee Retired
That's a good point.
Well I guess a CPU mod on the Pro; or purchasing a server (new or second hand that supports 64-bit, depending how often you upgrade your servers and how big your organisation is you may have a spare one lying around or one soon to be decommisioned from production use) and using VMWare ESXi would be the way to go if you need to run 64-bit VMs. If you already have a Pro (and even probably if you don't), using the ReadyNas as a VMWare Datastore would certainly be cheaper than buying a 3200.
