chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
ptaylor874
Jan 31, 2010Tutor
Well, I have a spare E7200 processor, but from reading the other post, it sounds like nothing about the E6X00 series is supported...
In my case there's no requirement to run R2, except that I thought it would be supported by Microsoft longer than the x86 version... That'll probably do just fine for my purposes.
