chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
TeknoJnky
Mar 10, 2010Hero
is there a solution for this?
Also, is it safe to run apt-get upgrade? when I tried on the original install (before I defaulted to get x-raid2 dr) it said something about mysql server errors.
sauron:~# apt-get update
Get:1 http://download.virtualbox.org etch Release.gpg [197B]
Hit http://download.virtualbox.org etch Release
Ign http://www.readynas.com 4.2.7/ Release.gpg
Ign http://download.virtualbox.org etch/non-free Packages/DiffIndex
Get:2 http://ftp.debian.org etch Release.gpg [1032B]
Hit http://download.virtualbox.org etch/non-free Packages
Hit http://ftp.debian.org etch Release
Ign http://www.readynas.com 4.2.7/ Packages/DiffIndex
Ign http://ftp.debian.org etch/main Packages/DiffIndex
Hit http://www.readynas.com 4.2.7/ Packages
Hit http://ftp.debian.org etch/main Packages
Fetched 2B in 1s (1B/s)
Reading package lists... Done
sauron:~# apt-get install virtualbox-3.1
Building dependency tree... Done
Recommended packages:
libpulse0 libsdl-ttf2.0-0 linux-headers libhal1 pdf-viewer python-central
The following NEW packages will be installed:
virtualbox-3.1
0 upgraded, 1 newly installed, 0 to remove and 24 not upgraded.
Need to get 51.8MB of archives.
After unpacking 104MB of additional disk space will be used.
Err http://download.virtualbox.org etch/non-free virtualbox-3.1 3.1.4-57640_Debi an_etch
302 Moved Temporarily
Failed to fetch http://download.virtualbox.org/virtualbox/debian/pool/non-free/v /virtualbox-3.1/virtualbox-3.1_3.1.4-57640_Debian_etch_i386.deb 302 Moved Tempo rarily
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mis sing?
sauron:~#
