chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Mar 15, 2010Luminary
Confirmed, the BIOS has VT-x enabled by default.
chirpa wrote: I should be able to verify this tomorrow, going to be testing some other CPUs in the Pro.
MikeMcr wrote: Does this mean VT-x support is enabled by default in the ReadyNAS BIOS (which we don't have access to)? I know with some motherboards you actually have to enable it when swapping in a compatible CPU.
