chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
May 09, 2010Mentor
Mackila wrote: Mack-NAS:~# VBoxHeadless --startvm XP --vrdp on &
[1] 27947
Mack-NAS:~# VBoxHeadless: Error -1912 in supR3HardenedMainInitRuntime!
VBoxHeadless: RTR3Init failed with rc=-1912
VBoxHeadless: Tip! It may help to reinstall VirtualBox.
The problem quite likely is that you installed an i386 version of VirtualBox while you need the AMD64 one.
If you installed VirtualBox using apt-get, first remove that version:
apt-get remove virtualbox-3.1
Next, get the correct installer and run it:
wget http://download.virtualbox.org/virtualbox/3.1.6/VirtualBox-3.1.6-59338-Linux_amd64.run
chmod 755 VirtualBox-3.1.6-59338-Linux_amd64.run
./VirtualBox-3.1.6-59338-Linux_amd64.run
As a last step, install the missing library using apt-get:
apt-get install lib64stdc++6
Then proceed as you usually would.
That's how it worked for me.
-Stefan
