chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Mackila
May 09, 2010Aspirant
Thanks !
Installing lib64stdc++6 made things change a bit.
I now have this :
Googled "libz.so.1", guys say "apt-get install zlib1g"
Do you remember doing other things for getting your virtualbox working ?
edit :
of course I got a libz.so.1 file under /usr/lib
I now have this :
Mack-NAS:/c/backup/VirtualBox# VBoxManage list hostinfo
/opt/VirtualBox/VBoxManage: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
Mack-NAS:/c/backup/VirtualBox# apt-get install zlib1g
Reading package lists... Done
Building dependency tree... Done
zlib1g is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
edit :
Mack-NAS:/usr/lib# ls -al libz.so.1*
lrwxrwxrwx 1 root root 15 2010-05-05 16:30 libz.so.1 -> libz.so.1.2.3.3
-rw-r--r-- 1 root root 81012 2008-04-06 11:38 libz.so.1.2.3.3
