chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
May 09, 2010Mentor
Mackila wrote: (...)
of course I got a libz.so.1 file under /usr/lib
Sorry, I tend to compile most of the stuff manually, thus I tend to have some libs installed that are not normally part of the ReadyNAS distribution.
Please try:
apt-get install lib64z1
And see whether that helps.
-Stefan
