chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
May 09, 2010Mentor
Mackila wrote: Looks good. Will try later to configure and start a vm.
Thanks, I'll keep you up :) (eg posting a "works for me" step by step virtualbox install guide :) )
You do that and meanwhile I try to bake an add-on for the Pro ;)
-Stefan
