chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Mackila
May 13, 2010Aspirant
WhoCares? helped me by installing new 3.1.8 AMD64 .run binary of virtualbox.
We were able to successfully start virtual machines.
You need to apt-get some tools and libs to install virtualbox from binary installer (bzip2 as requested by binary installer, plus two libs - see last page of this thread).
As I got a brand new Pro yesterday, I will use it to make a step-by-step virtualbox install guide from factory reset-ed 4.1.9.
