chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
May 19, 2010Luminary
That first CODE box should say VIRTUALBOX, to match the first field in the 2nd CODE box, I must have been tired that night. Make sure both match and it should work for you.
